Is there something wrong with my Transmission?
Old Feb 15, 2009 | 04:37 PM
villam10's Avatar
Unhappy Is there something wrong with my Transmission?
Hi everyone, I'm new to this site but I have heard nothing but good things ab out it...so here I am.
I have a 2004 A4 1.8 T Auto...Every morning when I first start driving the transmission acts weird. It shifts fine once I take off, its the stoping part where its trouble. Just before it comes to a stop the transmission shifts back to first gear but it does it with a kick. As I drive the car for about 10-15 minutes it stops the rough 1st gear shift, but it does it every time I drive. ALSO, while it does the rough 1st gear shift sometimes after a complete stop the trans won't shift into gear even though its in drive.....I'll press the accelerator and the car will hesitate for 5-10 seconds before it catches the gear.....but as I said all this stuff lasts only for the first 10-15 min until the car warms up.
If you have any suggestions please let me know. Thanks, Andras.
Old Feb 15, 2009 | 04:46 PM
shane.trammell's Avatar
Are you driving in d or s? S will make it kick more due to early downshifts, but most of your symptoms don't sound normal. Make sure the fluid is full.
Old Feb 17, 2009 | 04:40 PM
villam10's Avatar
I only drive it in D....
Old Feb 25, 2009 | 10:56 PM
microkid's Avatar
I have exactly the same problem with my 2002 A4 1.8T Quattro. Any suggestions what the problem might be? Thanks!
Old Feb 26, 2009 | 08:10 PM
2muchboost's Avatar
Well if you have a FWD with CVT transmission then welcome to team. You are experiencing why AUDI went from a 5 plate to a 7 plate clutch due to the CVT and 5plate not holding the Torque put out from the motor. I own A4 2004 1.8T FWD with CVT and I had to replace my tranny to the tune of $7200.00. You may even feel a little shudder when the tranny moves from what would be 1st to 2end. Try replacing with SYN CVT fluid...And if you own a quattro then disregard what I said
Old Feb 27, 2009 | 03:33 PM
wolfdog's Avatar
I don't have an auto nor know much about them but first thing I would do is get the fluid checked or even replaced. It relies on that to switch gears properly.
Old Feb 28, 2009 | 10:49 PM
ee99ee's Avatar
I also had my CVT replaced for about $6200 a little over a year ago. Went from the 5-plat to 7-plate clutch. If you have a CVT, beware...
Do do you have a CVT (Multitronic) or normal auto (Tiptronic)?
-Chris
Old Mar 2, 2009 | 08:57 PM
microkid's Avatar
My car has a normal auto (Tiptronic).
adumbtwit
Nov 28, 2013 04:13 PM
sttrebo
Apr 12, 2012 05:43 PM
primoaudi
Jan 19, 2011 08:45 AM
