Tranny wont move gears...
Old Jun 8, 2010 | 12:49 AM
DanaB6's Avatar
Default Tranny wont move gears...
Alright just now i started my car, put it into drive and then noticed on the speedometer there was no "red box" around the D symbol, so i ignore it thinking its something non-important...I start driving and the car won't get out of 1st gear, i try the triptronic mode and nothing happens it wont even move gears...I just attempted to re-start my car over and over hoping it would go away but no...It wont move gears in drive. Reverse and parking work, same with neutral...What could be the problem?
I have a 2003 a4 3.0
Old Jun 8, 2010 | 01:16 AM
DanaB6's Avatar
i just turned my car on to see if going 35mph would do anything, but it went into gear and worked fine, so i turned it on and off 10 times to see what would happen but it worked all 10 times. So now my tranny works? and a few minutes ago it did not..
Old Jun 8, 2010 | 04:46 AM
rwb's Avatar
rwb
Do you have a quattro or a cvt???
Old Jun 8, 2010 | 12:07 PM
DanaB6's Avatar
quattro
Old Jun 8, 2010 | 06:52 PM
rwb's Avatar
rwb
If it was a cvt I would tell you that your tcm is dying, but since you have the quattro auto try removing the electrical connectors from the transmission and cleaning out the inside of them and also check to make sure that they are connecting tightly. If that doesn't work hopefully somebody else will chime in with some ideas.
Old Jun 9, 2010 | 02:50 AM
DanaB6's Avatar
Found out it was my ignition safety switch, had one spare lying around the shop, replaced it and worked fine.
Old Jul 17, 2011 | 01:48 AM
tyang's Avatar
Default tranny didnt move when in reverse
hi, what is tcm ? i have a 03 1.8t front wheel and i think tcm is the problem with my car . my PRND flashes sometime but not all the time and today, my car wouldnt go in reverse during this one time that i try to reverse but now everythings ok again.... can i fix this myself and how much will it cost ?? what do i need to change or replace ? helppp .....one other thing...my oil flashes sometime in my dash...but my oil is full at oil stick...whats wrong ?? is this a big problem ?? helpp
Old Jul 17, 2011 | 08:19 AM
rwb's Avatar
rwb
The TCM is your transmission control module. On the evil cvt transmissions they are what fails first. If it fails and you don't fix it quick enough your transmission will be toast. If you need to get it rebuilt try bba remanufacturing. A google search will bring them up.
Sammy~D
Jan 15, 2012 12:44 AM
sweetlou
Feb 28, 2011 04:46 PM
ericp1.8T
Mar 26, 2010 07:59 AM
hatinyet
Oct 27, 2009 05:08 PM
DENIS415
Aug 14, 2006 02:35 AM
