Trunk keeps popping?
Old May 11, 2009 | 02:47 PM
TheAudiAffect's Avatar
Default Trunk keeps popping?
hey guys,
The trunk on my 04 a4 usp keeps popping open on me. it pops if im sitting without the key in the ign. it also does it while its running and not running with the key in the ign. a friend told me that it might be happening because the battery in my key might be close to dead. i removed the battery and it still does it. i haven't heared of this happening to anyone and im sick of pulling over after a traffic light to close it. is there a module or something that could be going bad?
Thanks for any and all help.
Old May 13, 2009 | 02:44 PM
bump... anyone?
Old May 13, 2009 | 05:53 PM
auditech79's Avatar
The latch is electrical, it commonly has problem with the contacts which is most likely causing the unwanted opening of the lid. Replace the latch located on the TRUNK LID, not the striker.
Old May 14, 2009 | 02:27 PM
ok awesome, thanks. hopefully they aren't too expensive, i have alot of p.m. work thats due.
Old May 14, 2009 | 02:41 PM
Midniteoyl's Avatar
Take it out and try to clean it first...Also, trace the wire back and make sure its not damaged.
Old May 15, 2009 | 11:15 AM
Cas1985's Avatar
both auditech and midnite gave you good advice. it sounds like an intermittent electrical problem. chaffed wires can be your worst enemy, even just a little nick and it can be very hard to find. good luck!
Gecko Asiks
Feb 26, 2018 11:13 AM
jp196400
May 12, 2011 03:13 PM
pbrules10
Feb 15, 2011 11:13 PM
cbouslim
Dec 25, 2008 11:48 PM
TurboQuattroPwr
Jun 2, 2006 08:03 PM
