TurboCharger Replacement
Old Apr 23, 2008 | 03:41 PM
bryantzj's Avatar
Default TurboCharger Replacement
Please help![]
I have a 2002 A4 T1.8 (100k miles) My turbocharger has died and I purchased a factorymodel one off of TurboChargerPros. However my mechanic states the car is still smoking. Once heremoves the turbochargerhe notices oil insidewhere it shouldn't be. Under the assumption that the first 2 turbochargers I got from them he reasoned that they were inoperable (turbochargerpro model). He seems unable to figure it out. Any suggestions on why oil is burning inside the Turbo?
Old Apr 23, 2008 | 04:36 PM
cincyTT's Avatar
I'm make believe
Default RE: TurboCharger Replacement
The return line is clogged or something to that effect.
Old Apr 23, 2008 | 06:43 PM
bryantzj's Avatar
Yes the oil flow lines where checked and were fine also.
Old Apr 23, 2008 | 08:23 PM
cincyTT's Avatar
I'm make believe
Are you sure it isnt a valve cover gasket leaking in the same location?
Old Apr 23, 2008 | 08:45 PM
bryantzj's Avatar
Yes. The cover was removed and there was no oil on the heads. To be clear there is no oil leak. But inside the Turbo where the exhaust leaves there is oil located in that valve.
Old Jul 21, 2019 | 05:42 PM
hbasque@hotmail.com's Avatar
I know this is late reply, but a situation like this calls for a cleanup of the intercooler . During bad turbo time, the oil will spill in the intercooler. If the intercooler is not rinsed out, oil will burn in the turbo for some time.
JHB
Old Jul 24, 2019 | 11:00 AM
Kurko's Avatar
Check the ccv system too
Old Jul 8, 2024 | 01:51 PM
PercivalShortz's Avatar
gigglebeans
Dec 5, 2012 10:47 PM
A4 2000
Nov 18, 2010 11:54 AM
Cortez2306
Nov 1, 2009 02:51 PM
docp
Dec 17, 2007 08:22 PM
A4nicator
Feb 13, 2007 10:41 PM
