Two codes thrown on my Audi.
Old Feb 21, 2011 | 07:44 PM
treyg's Avatar
Default Two codes thrown on my Audi.
P0011 - Camshaft Position Timing Over Advanced
P1118 - O2 Sensor Heater Circ.,Bank1-Sensor2 Open
What do I do to get these resolved as quickly as possible. Replace the sensor for the second code but what about the first? Can I adjust the timing myself or will I need to have it done?
Old Feb 21, 2011 | 11:01 PM
auditech79's Avatar
Did you just have your timing belt changed?
The second code means you need a new O2 sensor (after cat)
Old Feb 21, 2011 | 11:06 PM
treyg's Avatar
I bought the car a little over a month ago. I have all the service records and the timing belt was changed at 89k miles and hasn't been messed with since.
Old Feb 22, 2011 | 12:29 AM
auditech79's Avatar
An over advanced code generally means the belt is too tight, or its a tooth advanced. Take off the upper cover and check the tension of the belt. If you can't twist the belt 90 degrees its way too tight. If the tension is fine line it up to TDC and check the marks.
willie7182
May 16, 2011 01:46 PM
Audi_Skydiver
Oct 29, 2009 10:02 PM
audizz a4
Dec 2, 2008 01:47 AM
jgm7507
Jul 14, 2008 12:29 AM
BFlan2001
Sep 4, 2005 08:24 PM
