Vibration
Old Aug 24, 2009 | 10:59 PM
Boostmore's Avatar
Member
Default Vibration
Seems like I've got a vibration from the front right of my car when applying any force on the right tire.
So far I've:
Swapped Tires and rims (Brand new)
Removed / added spacers
Wheel Bearing
Rotors
I am leaning to believe it would be a bad CV Joint, but still unsure! This only tends to happen after 60 KMH (30MPH) and on. Yes, tires have been balanced numerous times!
Old Aug 24, 2009 | 11:07 PM
audiprotein's Avatar
yep, chekc your cv joint. look carefully right there see if you can find any grease
Old Aug 24, 2009 | 11:40 PM
Boostmore's Avatar
Member
Yeah, maybe I can find some but it seems near impossible to see any.
Old Aug 25, 2009 | 09:19 AM
shane.trammell's Avatar
You should be able to see the whole axle from the bottom with the belly pan off.
Old Aug 25, 2009 | 11:03 AM
soundisgood's Avatar
I had to replace my right axle after I started getting a vibration. While I could see plenty of grease I also noticed that when giving the axle a good tug, on the right it had a little movement but the left was rock solid.
Here is a DIY. http://www.a4mods.com/index.php?page...ages/axle.html
Mnew
Jan 22, 2012 12:06 PM
Bluv
Oct 5, 2009 05:43 PM
Fernandus
May 31, 2008 08:16 PM
aabbyen
Aug 18, 2007 04:07 PM
Ziggy2609
Mar 15, 2006 10:53 PM
