whining noise in front end when turning
Old Mar 23, 2011 | 09:40 PM
caseyg92's Avatar
Default whining noise in front end when turning
so whenever i turn a little no matter waht way it is like a whining noise coming from the front. i dont know if its the power steering pump or if its normal for a a4 quattro?
Old Mar 24, 2011 | 05:43 PM
Audi Tek's Avatar
Tech Certified
Power steering pump, but you should check your steering rack. The bellows boot that connects to your tierods.... poke a small hole in it if fluid comes out. You'll need a rack as well.
Old Mar 24, 2011 | 09:34 PM
esandes's Avatar
Banned
change the power steering fluid ASAP
Old Mar 26, 2011 | 09:23 AM
caseyg92's Avatar
could it be a wheel bearing?
Old Mar 26, 2011 | 11:23 AM
ImTheDevil's Avatar
No, it's power steering related. Check the fluid level first.
Old Mar 26, 2011 | 04:17 PM
auditech79's Avatar
The power steering fluid is mineral based, which are known to evaporate over time. Audi recommends topping them off every 10-15k. I've seen cars with less than 15k on the clock with the resivior almost empty, topping them off was all they needed.
You may also have aerate the system if its got to much air in there, basically top the fluid off, leave the cap off the resivior, and turn the wheel lock to lock until all the bubbles in the resivior stop.
GetAud!here
Nov 25, 2009 11:17 AM
ivan22
Jun 5, 2009 06:37 PM
Jetzeus
Dec 3, 2007 12:03 AM
