05 Quatro, P0302 plus Chirping
Old Nov 16, 2013 | 01:32 PM
masamune's Avatar
Default 05 Quatro, P0302 plus Chirping
Hello all. I am having a bit of an issue with my A4. To cut to the chase, I am having a Misfire in Cylinder number 2 at 2k rpms, at 40-60 mph, that is preempted by a chirping noise.
I have replaced all 4 Ignition coils within the last year. While I am vaguely familiar with cylinder miss fires, I have never noticed this chirp before. It always preempts the misfire.
Any Ideas? An exhaust valve maybe? Thanks in advanced for your help.
Update:
So I Changed out all of my plugs, and swapped my center Ignition Coils. This caused the fault to move to Cylinder 3. I went and swapped the Ignition coil in #3 with a brand new one straight from Auto zone, with no Effect. After this I removed #2 and #3 Plugs to inspect if the antiseize may of fauled the plugs, but they were good. Lastly I shifted all the coils down 1 (4 to 3, 3 to 2.... you get the idea) with no effect. So now I have a Misfire in Cylinder 3, New Plugs, and more questions then answers.
Old Nov 17, 2013 | 08:11 AM
M5S5's Avatar
Tech Certified
So your misfire moved from cylinder 2 to cylinder 3?
You are best to stick with OEM on the ignition coils , they are only about $20 each. Autozone is chock full of cheap Chinese crap.
krimsanavenger
Apr 7, 2011 05:04 PM
fuzz_duster
May 9, 2008 11:54 PM
munkee
Mar 11, 2008 02:07 PM
briguy3770
Jan 28, 2008 11:10 PM
barnes33434
Nov 3, 2007 01:38 PM
