Audi A4 06 Rear Door Problem
Old Feb 10, 2011 | 03:52 PM
Kbozo94's Avatar
Default Audi A4 06 Rear Door Problem
Hey i just purchased an Audi recently and im having some trouble with the driver side rear door. The door locks fine but when unlocked it will not open from the outside. The door does not make that clicking sound as ive it unlocked. Once the door is unlocked it will open fine from inside and out. If someone could help me out with the problem it would be great. Thank you!
Old Feb 14, 2011 | 10:18 AM
mikejaeggi's Avatar
I am having the same issue with my driver's door. the key fob works and locks all 4 doors. when I hit unlock, it unlocks all doors but the driver's door. I have tried a new key FOB and have the same issue. any ideas?
Old Feb 14, 2011 | 11:38 AM
Audi Dan's Avatar
Sounds like the solenoid could be either disconected, or has gone bad. Removal of the inner door panel might be the only way to check it. I'll check my manual tonight to see if I can get any info.
Old Feb 14, 2011 | 04:17 PM
esandes's Avatar
Banned
for the back doors: perhaps the door has been child locked. open the door and look at the side and unlock it or see what position the lock is in.
Old Feb 17, 2011 | 12:04 PM
Audi Dan's Avatar
Sorry it took so long to get back to you. I checked my Bentley manual, which is kind of a bitch to use. I found that the '06 A4 uses two motors (solenoids) at each lock. One locks the door, the other un-locks. It sounds like the un-lock motor is either dis-connected or gone bad.
These motors are located right at the latch point. You would need to remove the inner panel to access them. The bad news is the motors are part of the latch/lock assembly and cannot be replaced individually. The only hope you have for a cheap fix is a bad connection. Don't assume that the fault in the circuit has to be at the latch area. Trace the wire back as far as you can, as it could be down around the hinge or wire passage into the door from the "B" pillar.
Good luck
nottiaudi
May 1, 2013 01:59 PM
lord_of_lostock
Mar 28, 2013 02:59 PM
yampie77
May 25, 2009 02:56 PM
smoovmusicdj
Feb 15, 2008 05:38 AM
Danielm
Feb 4, 2006 07:05 PM
