carpet
Old Feb 14, 2010 | 01:07 PM
diggs's Avatar
Default carpet
i have a 2005.5 audi a4 . tan inter.... can anyone tell me how to go about getting new carpet and how it is installed really?........ i dont know anything on the subject but i put to cigg holes.... in my a4.... bad......
Old Feb 15, 2010 | 08:33 AM
phosphateb's Avatar
i would hand clean your carpet with some auto shop spray product..forgot the name of one but it works well..blue something anywho...scrape out the burn and/or see if you can cover it..if not... only you will see it and care :-)
Old Feb 15, 2010 | 04:37 PM
diggs's Avatar
yeah thats cool, i can clean it to a certain ext......... i didnt know if anyone ever had ther carpet replaced or if theres a company that sells the oem carpet..... or if u have to just go through audi.... its a subject i know nothing about...... but imput helps
Old Feb 15, 2010 | 05:33 PM
Gordon Freeman Jr's Avatar
Take a scissor and cut up a small amount of fibers from a good spot. Get yourself use some Elmers glue or maybe some of that spray glue in a can and put a very small amount into the holes, after you clean then with an old toothbrush. You will probably also want to vacuum up any debris, so you don't end up gluing debris to your carpet for that permanent dirty look. After you put the *small* amount of glue in there, put some of the fibers in each hole and make sure they mix with the glue. Leave it set for an hour or so and you should be good to go.
Old Feb 16, 2010 | 01:20 AM
Quattros's Avatar
well to get new new carpet, you would have to buy a new one or used and remove the seat plus some panels. the carpet comes all one piece, front to rear so you would be changing the front along with the rear.
Old Feb 17, 2010 | 10:07 PM
Audi Tek's Avatar
Tech Certified
you best bet would be to go to an upholestry shop and inquire there.....
You don't want to know the dealer cost for replacing a carpet....... talking over 2,000.00 easily
diggs
Jun 13, 2013 07:28 PM
neomaxddr
Mar 20, 2009 11:43 PM
BadMajik
Apr 20, 2008 10:03 PM
95AudiA6
Jan 1, 2007 03:54 AM
mtwood60
Sep 24, 2006 10:22 PM
