engine coolant sensor circuit high
Old Aug 28, 2016 | 05:43 AM
grahamjf's Avatar
Post engine coolant sensor circuit high
Hi all
Took my Audi A4 2.0TDI 2005 in to Audi to get a diagnostic check done and it came back with P0118 engine coolant temperature sensor 1 circuit high.
I have changed the ect sensor with a genuine audi one before it went in to get scanned, The temperature gauge dos'nt move off the cold unless the car is booted going up hill, dosnt even reach the first notch even on a really hot day, When it does move, after you stop booting it up hill it drops back to cold again.
The thermostat was changed as well 88degree
What does high circuit mean?
Any ideas on what wrong?
Old Aug 28, 2016 | 05:52 AM
grahamjf's Avatar
Did read about trying this but not sure if this could cause further damage or not
unplug the sensor and, using a fused jumper wire, jumper the two terminals of the connector together. The temperature reading should now be maxed out
Read more at: OBD-II Trouble Code: P0118 Engine Coolant Temperature Circuit High Input
Copyright OBD-Codes.com
Red_sapphire89
Mar 8, 2008 10:19 PM
AudiTurbo
Aug 22, 2007 11:32 PM
gregp1962
Sep 27, 2004 01:43 AM
