hard to steer
Old Dec 20, 2009 | 02:55 PM
02audia4tb's Avatar
Default hard to steer
Hey guys i was out playin in the snow last night and i lost my power steering assist. i checked the belt and fluid level: all good. it seems to only be at low rpm range when it is hard to turn. if you rev it up some it turns normal. anyone else run into anything like this?
Old Dec 21, 2009 | 12:46 AM
marcus02390's Avatar
Member
I did this two days ago and have the same problem. There was a older post like this and possibly had a solution but forgot what is was called and can't find it anymore.
Old Jan 17, 2010 | 09:53 PM
rowyourown's Avatar
All b7s have variable steering, so it should be lighter at lower speeds and heavier at higher speeds, maybe its an issue with that system.
Old Jan 18, 2010 | 10:55 PM
clemsongt's Avatar
Servotronic fuse? A lot of guys actually remove this fuse to get a better response from the steering wheel.
If you open the fuse box and look behind the fuses you will see a couple bigger fuses labeled 640 and 641. The 640 fuse runs the steering assist and may have gone bad.
Old Jan 21, 2010 | 06:39 PM
Audi Tek's Avatar
Tech Certified
Servotronic relay........... Yes, most likely your problem if the pump and fluid are fine
my hands can't get at it thru there.... so you may have to remove the lower panel
o0hmikee
Nov 10, 2012 08:21 AM
sonny2
Dealerships
Sep 1, 2010 01:32 PM
aoh35
Aug 16, 2007 11:15 PM
AWDaholic
Oct 3, 2005 05:55 AM
Norespect
Jan 8, 2005 09:36 AM
