help with TPS tire pressure sensor
Old Sep 24, 2008 | 06:53 PM
bestint's Avatar
Default help with TPS tire pressure sensor
how do i reset the tire pressure sensor? the indicator came on after putting air in the tires, i did a system check and still the indicator comes back on. is there another way to reset it? do i have to go to the dealer?
Old Sep 25, 2008 | 03:53 PM
jasondmaguire's Avatar
you need to go into the menu and reset it. Its not that hard.
Old Sep 26, 2008 | 06:27 AM
ocadam's Avatar
either you over filled it or maybe check that spare.
Old Oct 15, 2008 | 02:05 AM
JOOTZ's Avatar
^^^ didnt think the spare tire is hooked-up too, indicator light turned on today, will try the reset
Old Jan 18, 2010 | 07:31 PM
bestint's Avatar
awesome. customer figured it out. thanks guys.
Old Jan 21, 2010 | 06:41 PM
Audi Tek's Avatar
Tech Certified
its reset on the stalk switch menu if the car doesn't have MMI....
and Yes...... the spare is always monitored too.
Old Sep 22, 2010 | 01:05 PM
hoyaprof's Avatar
Got an Audi A4 Quattro five days ago. Today the tire pressure sensor was activated. I went to the gas station and checked he pressure in all four tires. Two were at 40, one 41, and the fourth at 38. Seem to me that they were all properly inflated. I topped of the 38 to 40 and reset the sensor. Is the sensor that sensitive to detect that one tire had two pounds less than the others? Or, did the sensor malfunction?
Old Nov 29, 2010 | 11:36 PM
bockegg's Avatar
check the spare tire and inflate it to the same pressure.
pdxrado
Jan 28, 2013 06:35 PM
floyd72889
May 27, 2012 09:23 AM
wilmingtonhomes
Dec 13, 2011 07:03 PM
timindp
Oct 15, 2010 09:44 PM
azbryanw
Jan 11, 2010 02:26 AM
