HID kit with normal housing?
Old Feb 8, 2008 | 09:38 PM
themig90's Avatar
Default HID kit with normal housing?
Thinking about getting an HID kit with a normal halogen housing, will this be a bad idea or should I go for it?
Thanks in advance
Old Feb 10, 2008 | 03:42 PM
blackman235's Avatar
Default RE: HID kit with normal housing?
first off It depends on how much money you want to spend. Alot of people will tell you its a bad idea because of the glare most kits give off in halogen housings. If you can get a kit kit with a rebased d2r bulb then you should be fine because those bulbs are made for relector housings. This is what nissan and lexus ect. did, the housings are the same for both hal.and hid models just differnt bulb (d2r) electronics ect. also I heard if you dont get a relay for it too the kit will throw a code and your lights won't work at all. Now if money is not a problem just get the factory hid setup its expensive but its the best bet. Personally I'm ging with first option, I think it looks a little more high class since every one has the d2s aftermarket kits, and custom prjector setup that could run you $1500+ my option is about 350 + or -. You don't get the same throw because the lights aren't as intense as d2s bulbs but they have a nice smooth soft spred on them, kinda cool
http://www.hidexpert.com/ph7_adapters.html
http://www.hidexpert.com/pd2r.html
you would need that plus a balast kit
forgot to tell you that you would not have high beams if you go my route
Old Feb 10, 2008 | 04:36 PM
ocadam's Avatar
VVME.com easy to install, no codes and there cheap.
Old Feb 10, 2008 | 08:45 PM
ORIGINAL: ocadam
[sm=youreright.gif]
Old Feb 12, 2008 | 08:33 PM
OffshoreGuru's Avatar
ORIGINAL: blackman235
ORIGINAL: ocadam
[sm=youreright.gif]
Has anyone used VVME? Looking into this as well... thanks
coolwater
Jul 27, 2010 11:30 AM
Bklynrx7
Apr 21, 2009 12:55 PM
sampeck1324
Jun 29, 2008 07:45 PM
JohnnyBravoA4
Dec 18, 2006 06:24 PM
AHB900
Jun 3, 2006 10:20 AM
