Interior Climate Control/Temp issue-2006 A4
Old May 12, 2011 | 01:07 PM
Seastrike's Avatar
Default Interior Climate Control/Temp issue-2006 A4
Hi All - New to the site and looking for some insight to an issue.
The cliamte control system can't accurately control temp of inside air and it's driving me nuts.
I can set the int. temp to +70F and depending on the mood of the system it may blow cold air for a while, the warm air...It won't maintain the cabin temp as set.
Happened all winter long and is quite a pain.
One minute the interior may be comfortable, and the next Im getting blasted with cold air.
Happens in Auto or Manual mode and on both driver & passenger side.
The dealer says he's not getting any faulty codes. Im pulling my (already gray) hair out !
Appreciate your thoughts...
Old May 12, 2011 | 01:25 PM
dark153's Avatar
Does it happen when the "econ" function is on?
Maybe your Temp sensor might be acting up causing it to blow cold air.
Old May 12, 2011 | 02:16 PM
Seastrike's Avatar
Yes. Also w/ "Econ" on.
Old May 12, 2011 | 02:20 PM
Xarpolis's Avatar
That's odd. Econ mode means that the conditioning compressor isn't turning on. IE - It's just a vent to give you some wind inside the vehicle.
It's possible that your system is/has leaked and needs to be recharged. I would take it to the dealer again.
Old May 12, 2011 | 03:50 PM
Audi Dan's Avatar
Check for a vaccum leak. I think these cars used vaccum actuated doors in the HVAC ducting. Also a possible sticky mixer door
j_dinan
Feb 7, 2015 06:31 PM
Cjgrip
May 30, 2013 05:10 PM
andy_conf
Jun 27, 2012 02:30 PM
auttiquattro
Aug 11, 2007 10:56 AM
Suachris
Jun 16, 2005 01:00 PM
