Lot of plug info on here, and I'm a bit overwhelmed...
Old May 7, 2010 | 12:18 PM
SlackJaw's Avatar
Default Lot of plug info on here, and I'm a bit overwhelmed...
Could someone just TELL me what plugs I need...
B7 A4 2.0T APRchip.
Which plugs are best and appropriate gap please.
Thank you immensely.
Old May 7, 2010 | 04:41 PM
esandes's Avatar
Banned
from my personal research, OEM is the way to go. it should already be pre-gapped i think but it may be worth checking it anyways. i think the gap is spec'd at 0.028" and the model is Bosch FR6KPP332S.
some info:
http://www.golfmkv.com/forums/showthread.php?t=49635
Last edited by esandes; May 12, 2010 at 11:01 AM. Reason: got rid of the cooler plug suggestion
Old May 7, 2010 | 11:48 PM
SlackJaw's Avatar
Originally Posted by esandes
from my personal research, OEM is the way to go. it should already be pre-gapped i think but it may be worth checking it anyways. if you're running more boost, you might want to go with 1 step colder plug. i think the gap is spec'd at 0.028" and the model is Bosch FR6KPP332S.
some info:
perfecto. I couldn't figure out, colder, hotter, more gap less gap. I am going with your recommend, and look at your link, unless anyone come in here and call you a jackass
Thank you very much for the quick and informative response
Old May 9, 2010 | 04:36 PM
Otter11's Avatar
yeah def go with the stock Bosch. I have a Revo stage 2 chip, exhaust and a HFC. I just replaced mine when i did everything and that's the best way to go.
Old May 11, 2010 | 12:59 PM
esandes's Avatar
Banned
a good point was brought up in the thread about how the direct injection keeps things cooler in the combustion chamber even with higher boost. maybe that's why the colder plugs are failing. the tuner told him to use stock plugs and he got cooler ones anyways.
Old May 11, 2010 | 05:55 PM
SlackJaw's Avatar
so disregard your comment about going 1 step colder?
I'm not too worried about the stock - this things been chipped for coming on 2 years now, and never had a misfire code.
Old May 12, 2010 | 11:00 AM
esandes's Avatar
Banned
yeah just go stock, by the sounds of it. so how do you like the chip? how's the milage? i have the rev D diverter valve but not the aftermarket PCV. i've been wondering about chipping and exhaust (milltek or APR) w/ high flow cats for a while.
Old May 12, 2010 | 11:10 AM
SlackJaw's Avatar
I quite like it. word around here is that the GIAC is a little more aggressive in the lower RPMs, but I really like the fact that with the APR you don't have to replace the computer, and can turn it on/off via the cruise control stock. Also like that you can put multiple programs on there, although I just have the 93 octane and stock program. Either way, NOT cheap I can tell you that.
Mileage - I've heard that as long as your foot isn't in it, it will not affect. I can't give you a definite, as my foot is always in it I don't think it is noticeably affected though < 1 mpg city, if I had to guess.
Power-wise, the difference is very noiticeable, a worthwhile investment for me.
I NEED to put revD (although they say B7 don't require it) and PCV...I will probably do that when I change plugs...which I am due but procrastinating.
Bagheera223
S4
Mar 17, 2015 11:10 AM
manatee2000
B7 Models
Jan 11, 2014 10:24 PM
ee99ee
Oct 12, 2011 12:28 PM
werkwitdis
Jun 4, 2006 02:07 AM
