Low brake indicator always on even with new pads
Old Apr 19, 2015 | 07:49 PM
Hondadogie's Avatar
Default Low brake indicator always on even with new pads
How do I diagnose the system for the brake sensors? When pads are ok, should the sensor be an open or closed circuit? So I can tell if it's pads or the circuit.
Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
Old Apr 19, 2015 | 11:01 PM
imaudi5000's Avatar
i believe the circuit should be closed when the pads are good and then when they wear down too much, the wire in the middle gets ground down by the rotor and the warning light comes on. when i did mine last summer, the sensor/wire had just been exposed but was still intact. i dont think you can plug it in wrong, but check the connections and make sure they are clean and solid.
Old Apr 20, 2015 | 10:33 AM
mtroxel's Avatar
Brake sensors are for soccer moms.
Guys on these forums know when their brake pads are thin. Cut the plug off the car, connect the two wires and seal it up.
Old Apr 20, 2015 | 09:42 PM
imaudi5000's Avatar
brakes are for pussies, never stop!!!
jinsojoo
Sep 16, 2021 04:49 PM
tonymalice
Jul 17, 2013 02:05 AM
speedracr226
Aug 5, 2009 05:07 PM
black b5
Jun 1, 2005 09:36 PM
