Oil capacity error in manual
Old Sep 16, 2011 | 06:41 PM
B7Night's Avatar
Default Oil capacity error in manual
Has anyone else gotten their letter stating that the owners manual has the wrong oil capacity for your car's engine? Apparently the manual says that the 2.0t requres 4.5 quarts. The correction on the sheet of paper that you are to attach to the manual says that the correct capacity is 4.8 quarts. A third of a quart less makes an engine that is known use oil, just trigger the oil light that much quicker. Fortunately mine doesn't use oil. The 3.0 and the 3.2 also are wrong.
Old Sep 16, 2011 | 11:35 PM
esandes's Avatar
Banned
what years does this affect? i didn't get a letter. honestly though, 0.3 quart difference isn't much to lose sleep about.
Old Sep 17, 2011 | 08:17 AM
KingWulfgar's Avatar
I got one--it looked like it was just a misprint originally. The original stated 4.5 quarts/4.5 liters which isn't correct. 4.5 liters is 4.75 (or 4.8) quarts (the new capacity). I always check the dipstick about three times while and after I fill an engine, anyway.
Old Sep 17, 2011 | 10:53 AM
jagtoes's Avatar
If you use the OM for reference then you always know where to start. For the last 45+ years I have been working on cars I usually in this case will put in 4 qts. and start it up to fill the filter and get a little engine temp. Shut it down and wait a few minutes . Check it and fill it to the line. The only car this doesn't work with is my old Ferrari. You need to check the oil within 10-15 sec. and make sure it's in the safe area.
DCAV8R
Jan 23, 2023 06:33 AM
perryal
May 31, 2010 09:24 AM
ilovelagar
Oct 22, 2008 12:37 PM
a4se
Jan 3, 2006 08:05 AM
evansjb58
Nov 30, 2005 06:03 PM
