oil consumption out of line?
Old May 20, 2010 | 12:17 PM
skiracer1's Avatar
Default oil consumption out of line?
'08 2.0T AWD, 50K; seems the last 10K the "low oil level" light is consistently coming on right around 5K between oil changes. Oil changed at 10K per dealer spec, but finding I have to throw 1/2-3/4 qt. in until next oil change.
Here comes the "is this normal?" question. I know the 2.0T's have a tendency to gobble oil, my question is more like "why?". I do less city driving and more long haul driving, '05 didn't seem to have this problem, and I put 125K on that.
Ideas?
Old May 20, 2010 | 04:16 PM
B7Night's Avatar
It could be the PCV valve. Oil consumption increases when they go bad. The cars performance is also affected. Another sign is oil pooling around the filler cap. There are many other things that could be the cause too. My 06 has 51,000 miles and does not use a drop, which is unusual for the 2.0t.
Old May 21, 2010 | 12:45 PM
handyandhandsome's Avatar
Default Oil consumption
I have a 2008 2L turbo with 25k miles. I do mostly city driving. I too have had to add a quart of oil between the oil changes which surprised me. I just had my pcv valve replaced under warranty so I will see if this part replacement makes any diff in the oil consumption.
Old May 22, 2010 | 08:21 AM
smokn944's Avatar
It seems to be normal to burn some oil, but on my 06' 2.0T with 75K I do synthetic Motul every 6K and don't add nor does the oil light come on.
Old May 25, 2010 | 11:19 AM
skiracer1's Avatar
Update: So far no loss of power, no oil pooling, none leaking. Did replace the breather valve 10K ago; blowing oil out top. All nice, neat & tidy since. May replace PCV valve just for fun.
Old May 28, 2010 | 11:13 PM
Wandering Dane's Avatar
Default Another 2008 Turbo Burning Oil
2008 2.0 turbo with 23K miles; burns about a quart every 3,000.
Called the dealer this week to discuss; the service advisor mentioned that this is not unusual, said it is a combination of direct injection, turbo and high compression ratio. As a mechanical engineer, I don't buy into that 100% but I have had other unusual experiences with high oil consumption so I'll reserve any opinions for now.
The service advisor did mention that "stuck crankcase valves" have proven to cause oil consumption and suggested that I bring it in for a look-see. Will do next week, report back here if I learn anything of value.
The power delivery does appear a bit uneven, as if the engine is more eager or easy-reving sometimes more than at other times. I'll mention this, too, when I take it in.
Old May 29, 2010 | 02:26 AM
2wdBlazer's Avatar
Im due for a change as im right at 10K and I just checked it, Still at the full level and I have 80k miles. Now I gotta change it.
rfrank
Mar 12, 2015 02:48 PM
whoisthis
B7 Models
32
Nov 16, 2010 04:43 PM
TFT
Dec 21, 2009 11:45 AM
krishcanag
Jan 21, 2008 03:18 AM
vjreddy
Jul 25, 2007 04:15 PM
