Partial start question... I REALLY need help please!
Old Jun 29, 2011 | 09:15 PM
quattro179's Avatar
Default Partial start question... I REALLY need help please!
Hello all,
As you can tell it is my first post. I am a long time Audi owner, well for me at least. I got a 2001 B5 when I started driving. I just upgraded to a 2005.5 B7 3.2 quattro, and I am having a few problems so I hope someone can help.
The car only has 23k. I had everything checked out before I bought it, and it looked fine. A few things have already gone wrong though: trunk latch, passenger window, and cam sensors. But those are the least of my worries...
When I start my car when it is cold it does some crazy things. It is VERY inconsistent. In the beginning sometimes it started right up, and other times it took a little a little longer. But it always started first try. Now it does not. At least every other time I try to start it when its cold it does not start. I do not even know how to describe what happens. Its not like the car won't turn over, it just has some weird troubles. It turns on, but the car is only "partially" started. It almost sounds like half of the cylinders are running. It will run like that for a while. I usually have to turn the key off for it to stop. One time I even got out and popped the hood. It was easy to tell that something is going on. The whole engine was moving, and maybe even vibrating more than when it is actually running. I have become very paranoid about it, and make sure the key is turned all the way every time and keep it there for a few seconds. Even when being this conscious the car will still do the same thing! One time it even kept running partially after the key was turned off and removed.
It has been to the dealer. They have never heard of anything like this, and did not act this way the day it was there. Go figure. There were 7 sporadic fault codes, all involving the main computer interacting with the other modules. Each one was different too. It would interact wrong with the powertrain, steering system, airbag etc. You name it and it pretty much happened. Any ideas as to what the problem could be.
The only thing I have changed are the visors, which I bought off eBay. I was removing the stickers and accidentally got alcohol on the Homelink buttons, so I bought new ones. I just thought of the chance of this being the problem, but I think its a long shot. I will try switching back to the old visors tomorrow.
Any other ideas you may have would be appreciated, the whole situation is really freaking me out.
Thanks!
Old Jun 30, 2011 | 09:50 AM
jagtoes's Avatar
When the dealer read the codes what did they do. Does the 1st code always show up after the CEL has been erased and reset. Also did the dealer check the ignition key to see if you have a problem there. I would go back and start looking at what sets the 1st code.
foxracing4500
Mar 20, 2011 01:47 PM
nitrorocket
Nov 19, 2010 01:30 AM
qUaTtRoA4
Jan 29, 2008 12:40 AM
Lear70
Oct 18, 2006 11:40 PM
quattrosedan
Jan 20, 2006 12:16 AM
