stuttering/shuddering issues
Old Feb 21, 2014 | 06:57 PM
dbaseballs's Avatar
Good news everyone! The car finally threw a code and it was a misfire. The coil on cylinder 2 went bad and with a $22 part it is fixed
Old Feb 22, 2014 | 11:41 PM
bubbarivi's Avatar
It might be the dv valve. Could have a small rip in diaphragm and causin boost loss. replace by 60K with the upgrade and check cam follower. Can get both for about $100 and it is a must to replace before they go bad
Old Feb 23, 2014 | 08:03 AM
willieolivier's Avatar
Default My two cents worth
I also had this happen to me although mine was a 1996 model. I'm no expert so I just type what I understand was wrong with my car.
The problems eventually got worse until one day it wouldn't run anymore - I was convinced it was fuel pump related.
To make a long story short - it turns out that one of the vacuum release pipes were blocked - this in turn caused a suck/vacuum effect in the tank which caused damaged to the fuel pump wiring (from cap going down to pump) through the years up to the point where it snapped the brown wire.
The way I understand this is that the pump didn't always get power because of this wire not always connecting - until the snap.
Anyways now my car runs fine and smooth again.
Tremar
Jul 11, 2012 10:21 PM
okblue_fd
Jan 10, 2012 10:04 AM
dohalloran
Oct 27, 2011 01:38 PM
kingfisher
Jul 26, 2009 07:46 PM
BrianVarick
May 21, 2008 12:04 PM
