test pipe vs high flow cat
Old Sep 15, 2012 | 09:21 AM
Jebs451's Avatar
haha yea thys wut i want something that almost sounds stock til u hit it..how much r they?
Old Sep 16, 2012 | 09:50 PM
A4Cragman's Avatar
Depends where you get it. Just Google stasis dealers near you and shop around
Old Sep 26, 2012 | 11:52 AM
optifreeeyesolution's Avatar
i have a test pipe in my 06 2.0. all you have to do is buy an angled spacer for the secondary oxygen sensor, easy fix. and for the difference of them, i have no idea. i would say they are the same, both are just empty pipes, no filters.
Old Sep 26, 2012 | 05:12 PM
A4Cragman's Avatar
^False. A high flow cat isn't an empty pipe, the catalyst is still in there, its just packed in a far more efficient manner that still cleans the exhaust without significantly impacting flow. That little bit of added resistance, though minor, does still affect the note. There are several videos on youtube that have side by side comparisons of everything from just a test pipe vs stock, a test pipe and downpipe but no mufflers vs stock, a HFC with downpipe vs stock vs just test pipe, etc.
Old Sep 27, 2012 | 06:51 AM
Jebs451's Avatar
ok good to no but y do the y say the hfc will throw a check engine light?
Old Sep 27, 2012 | 09:03 AM
That's why I assumed they are the same, if it has a filter why would the check engine light go off. Is their a performance difference?
Old Sep 27, 2012 | 02:25 PM
A4Cragman's Avatar
It *can* throw a code just because of the higher flow; some cars do, others don't. The actual emissions reading if you were to test the exhaust with the hfc will still read clean, but the higher flow in some cases can still throw a light. Basically, the sensor is configured to read x clean particles per y volume of gas, but with the hfc its still getting x clean particles per z volume gas where z>y so it thinks something is wrong and throws the code. The end result is still the same required x clean particles, the sensor is just reading a lower ratio because the flow is greater. Thus the adapter comes in and all that does is reduces how much of the sensor is in the exhaust stream so it forces it to register less volume and then the numbers line up again to make the computer happy.
Old Oct 2, 2012 | 02:41 PM
  #18
2wdBlazer's Avatar
I would not get one of those spacers to fool the computer. I have only personally seen them work on these cars and VW's with the same engine about 25% of the time. Very hit and miss. A tune will fix the light and give you power.
High flow cat will cost more and have a little less power and smell better.
Test pipe will be cheap on ebay, have more power and stink for people right behind you.
I went the test pipe route and made the car louder and kept the stock exhaust. Much cheaper that way.
Please try to type better as those posts hurt my brain.
Old Oct 10, 2012 | 06:55 PM
  #19
Jebs451's Avatar
Anyone ever experience eith a full catback custom exhaust?
daghstdrummer
Jun 9, 2009 03:29 PM
Jemmerling
May 7, 2009 09:23 PM
IOKEPA
Jan 17, 2008 12:25 AM
Selbach
Jul 29, 2007 11:00 PM
BadLuckAudi
Mar 1, 2006 11:22 AM
