tpms sensor problem??
hey guys whats up,
a few months ago this happened too and it went away after two days, so i ignored it and moved on, BUT it came back yesterday
i have the (recommended oem tire size 235/45/17) with the oem wheel, and the oem sensors on them, but lately the tpms light will come on for no reason,
1. i check all four tires for any holes or nails everythings looks good.
2. i check tire psi and they are all over 40 psi (good none low)
3. i am assuming that maybe a tpms sensor might be bad, ?? is this possible?? and if so i still have 4000 miles left before my warranty goes out, would this be covered under my warranty???? last i check or asked tpms sensors run about 50-100 bucks plus the labor to install it i.e: take off tire and replace sensor, then put tire back on. i have CLUSTER phobia so it annoys me when any sort of light comes on my dash lol
any info will be appreciated guys thanks!!!!!
Bringamac92-
Bringamac92-
tpms sensors go on the fritz constantly have had issues with my a4 as well as my x3
easy fix before thinking u need to go to dealer
be sure that all tire pressures are correct. don't use the bullshit air gauge attached to gas stations pumps.
i don't remember the exact steps and can't check since my wife has the audi atm but thru the stalk u can navigate thru the menu and reset ur tpms sensors
