Urgent - need help on winter wheel screw-up
Old Nov 17, 2009 | 11:55 PM
2wdBlazer's Avatar
Spacers are fine but you must run exactly 8 more mm on your lug bolts. Thats 1 way people **** up is to use the stock bolts. Other spacer that can be bad are the kind that change your pattern to another pattern. Those are bolted on and then the wheels are bolted to them. People tend to not check the tightness of the underbolts they can't see.
My first example is the best. A slide over hubcentric with longer bolts and you are golden.
Old Nov 18, 2009 | 08:32 AM
KLD's Avatar
KLD
Yep, 8mm H&R hubcentric spacers and 35mm bolts (stock are 27) are on their way.
Amybc96
B7 Models
Jun 29, 2015 07:37 PM
KLD
B7 Models
Nov 14, 2009 03:02 PM
KLD
B7 Models
Nov 14, 2009 02:59 PM
bigrig
Feb 22, 2009 06:32 PM
james0013
Mar 11, 2008 11:31 PM
