audi a4 b8 manual transmission noise
Hi My audi a4 b8 having a weird clunking noise coming from underneath the car when changing gears ( doesnt matter the engine turns off or while driving ) Im a bit worrying about this. Can you guys let me know what is wrong with my car ? Thanks a lot
inside the car ( hard to hear from the video ) :
Outside :
Outside :
How many miles are on the car. Do we assume it shifts OK and there are no gear noises. It sounds like a problem with the linkage . I would suspect it might be a bushing that is worn out and you are getting metal to metal contact causing the noise. You can either pull the shifter boot and look in from there or get the car on a lift and look from underneath as someone shifts it.
I'd have to see the linkage in action on a lift to be sure of anything
99turboaudi
Jun 17, 2008 09:49 PM
