changing factory settings on 2009
Have a 2009 2.0 TFSI
The car has APR tuned software on ecu.
I'm wondering if there is a way to set up settings like running lights, seatbelt chime, window rollers etc. without going to tuning shop?
If yes, what cable & software i have to use?
The guys installed APR said i have a raise in performance from 211 to like around 260 is that right?
They showed me how to swich between the factory & sports mode but after I did this once it is not working no more.(The swiching is seted up thru the cruise control arm).
Thank you
Thank you
it's called vag com. visit ross-tech.com and search on audizine.com for more info on the latest working cheap cable.
as for the APR chip, your stock HP is 211, after a chip, you have 234. there's not a standard number of higher performance, it's about balance.
put up a step by step of how you're trying to switch and i'll tell you what you're doing wrong
Or you can stop by and study Dave's site
http://www.audienthusiasts.com/VagCom.html
Very informative with links to indepth trouble shooting how-to discussions in Audizine
I'm doing it as it says in APR book.
First I swich the ignition on then push Cruise Control arm down.
Then enter my code (1212)
& after that push CC arm again... but nothing happend twho lights on dashboard(that suppuse to start blinking) never doing this.
I'm confused & i dont undestand how i did this the first time
go to their website - they made it for dummies, find yer stalk & go
now that I know your code, I'm gona have to steal yer car
mr X
Oct 23, 2009 08:56 PM
