OEM bluetooth
Old Jan 17, 2014 | 10:48 PM
mgrant99's Avatar
Default OEM bluetooth
New user looking?
I need information on adding Bluetooth in 2012 A4. I did not see a post on this but it must be my search techniques. Can the OEM stuff be installed if not what the best after market
Old Jan 19, 2014 | 08:25 AM
mgrant99's Avatar
Still lost on what aftermarket stuff works, the more I read the less I understand
Old Jan 19, 2014 | 04:25 PM
RyanLarson's Avatar
Not sure on OEM.
I have an 09 Audi A4 that has bluetooth integrated from the factory, so the phone part works OK, but doesn't stream music. I use this to stream music from my phone to my car stereo, works perfectly. You can also use this to make and answer phone calls from your car using bluetooth as well.
You'll need the MMI iPod cable in your glove box.
Amazon.com: ViseeO Tune2air WMA1000: Cell Phones & Accessories Amazon.com: ViseeO Tune2air WMA1000: Cell Phones & Accessories
Old Jan 19, 2014 | 10:15 PM
mgrant99's Avatar
thanks for the info on the ViseeO Tune2air. Since I have nothing in the glove box, I guess I need to keep digging. It seems very odd that I can not find a way to do this, still hoping for some more guidance.
Old Jan 20, 2014 | 08:21 AM
jagtoes's Avatar
To do OEM is cost prohibitive. That leaves you with aftermarket type divices similar to Motorola Roadster or Blue ant type units.
Old Jan 24, 2014 | 02:03 PM
TN69's Avatar
Check this out, might be something you are looking for FISCON Bluetooth Freisprecheinrichtung
Old Jan 26, 2014 | 08:46 PM
mgrant99's Avatar
Thanks this Fiscon looks good, I think I will give it a try.
Old Jan 28, 2014 | 05:48 AM
TN69's Avatar
Ok, I have one coming for myself.
I hope you noticed that they do not have Fiscon product for MMI 3G model, they recommended this product instead http://www.need4street.de/index.php/...79?language=en
Old Jan 31, 2014 | 06:05 PM
mgrant99's Avatar
Just had email with advice person, very helpful in verifying which product would work with my car. I asked him a question in a second email and I thought that I would share his reply. I know about bus systems (can bus, profi bus, etc) so I wanted to know if a programming device is needed to get there system to work. His reply was yes you have to code the car to work for the telephone function. And that your audi dealer could do this. This means the system will not work by just plugging it in. Maybe in Germany dealers are more likely to do this but I am not sure about the one I deal with. So now I am looking for programming devices and information on what address info I need to get the system from fiscon to work. Any one know this.
Old Feb 1, 2014 | 08:40 AM
TN69's Avatar
You need to find the person who has VCDS (Ross-Tech: VCDS). Then check this manual for the coding, the person with the VCDS can do that (http://www.fiscon-mobile.eu/support/...udi_pro_en.pdf). Make also sure that you have the right remove keys for the CD/CD changer before you start assembling.
bwright19
Aug 13, 2008 07:50 PM
