Tire pressure question
Old Feb 2, 2014 | 12:41 AM
A492's Avatar
Default Tire pressure question
Hey guys! My name is Rich and I just purchased a 2011 A4, so far I love the car and this forum looks awesome filled with very knowledgeable Audi enthusiast!
The past day my check tire light came on, I have only had the car 2 days and the tires look fine. Could this have just been triggered by the cold weather and the pressure is fine? Should pressure be at 32 psi at all times for all 4 tires
Thanks guys
Rich
Old Feb 2, 2014 | 12:48 PM
jagtoes's Avatar
Thanks guys
Rich
Check on the drivers side door frame. I believe it should be 35PSI front and 36PSI rear. After you put in the correct pressure go on the MMI screen under CAR and reset the tire pressure.
Old Feb 2, 2014 | 02:44 PM
MaineJon's Avatar
most certainly can be caused by cold weather. I find every winter, unless I add some just before, my tire pressure monitor will remind me it is winter and cold weather equals lower tire pressure.
Do as suggested - add to correct tire pressure and you should be fine.
Old Feb 2, 2014 | 04:54 PM
aspen79's Avatar
Every 10 degree drop in temperature equals about 1 psi drop in air pressure and vice-versa. That's tire temp not necessarily outside air temp. That's why you always check tire pressure on a cold tire (car not driven for at least 3 hours prior).
pdxrado
Jan 28, 2013 06:35 PM
auS4di
Dec 4, 2006 03:27 PM
TheJazz7
Jul 11, 2006 06:44 PM
Silver98A4
Nov 6, 2005 06:51 PM
prg435
Feb 19, 2005 02:09 PM
