P0299 code after installing cold air intake
Old Sep 6, 2022 | 11:17 PM
normb8's Avatar
Default P0299 code after installing cold air intake
Hiya, so like the title says I’ve been getting a P0299 code (turbocharger/ procharger underboost)
since installing a cold air intake. I installed the intake two days ago and today I sped up to make a light and then my CEL came on. After it came on the air flow sounded off and had a very weak turbo flutter as I shifted.
I was also messing around with a blow off valve spacer a little while ago but took it off because I didn’t like it.
i don’t know if I messed up installing the air intake or if I messed up the diverter valve or if I need new charge pipes or if my turbo is just done.
Old Jul 19, 2023 | 08:17 PM
GreenEdge's Avatar
Arrow turbobend.com
Your turbo maybe done, The good news is that you no longer need to put a new turbo. You can fix it in a minutes by using the turbo bend tool
www.turbobend.com
Good luck
Ckarm555
Jan 5, 2015 12:12 AM
ben G
Mar 8, 2009 08:42 PM
nickellis14
Jan 16, 2007 09:04 PM
russianari
Mar 24, 2005 03:12 PM
audiboy1618
Jul 4, 2004 08:20 AM
