PCV Valve Question
Old Mar 4, 2014 | 01:57 PM
B8tamaster's Avatar
Default PCV Valve Question
Hey guys,
So my MIL came on for the first time, read the codes, and she's throwing faults P0507 and P2279
After doing a little research and getting some good info from this forum, (thank you btw) I've narrowed it down to at least a bad PCV valve most likely. There is plenty of negative pressure in the crankcase, oil around filler cap, and bad idle when cap is off.
Now I went ahead and ordered a rebuild kit from autozone, with a new diaphragm and whatnot, in hopes that it might clear up my fault codes.
In the meantime, I'm wondering if anyone has opened the PCV valve and cleaned the inside of it, including the diaphragm, and have it work again. I'm suggesting this only if it's still intact, not cracked or damaged of course. Might a cleaning help a stuck diaphragm?
Let me know what you guys think. Thanks in advance!
Old Mar 7, 2014 | 03:29 PM
B8tamaster's Avatar
Well although nobody posted back I figured I would update.
Took the cap off the PCV and found this....
I was relieved to see that the diaphragm was damaged. Replaced the diaphragm and cap, cleared the codes out, and so far so good.
I also replaced the spark plugs and found this..
The plug on the top was from cylinder 2. When I went to pull it, it was really loose, like it was never torqued properly in the first place. As you can see the plug is basically destroyed, and was probably misfiring like a mother.
Old Mar 31, 2014 | 03:00 PM
mel23816's Avatar
is this the hockey puck like valve on top of the engine?
Old Mar 31, 2014 | 05:21 PM
FSures's Avatar
You are lucky. My PCV went south, pressurizing the engine and causing the rear main seal to blow. Never threw any codes prior to dumping oil out the back of the engine.
Old Apr 3, 2014 | 01:53 PM
B8tamaster's Avatar
Mel - yea that's the one.
FSures - I know, luckily the rebuild kit worked great. I was very worried about the seal blowing. I'm glad it threw the codes when it did
Old Apr 20, 2014 | 04:17 PM
tscottk's Avatar
Default 2010 a4 seems like same issue with PCV.
I'm getting the same codes and going through the same steps . How hard is the cover to remove? I don't want to break the pcv cap/cover.
Old Apr 21, 2014 | 10:03 AM
B8tamaster's Avatar
Honestly, it was a pain. I ended up just cutting the tabs off the cap because the rebuild kit comes with a new one anyway. I didn't really care about breaking it.
Old Apr 22, 2014 | 10:29 AM
tscottk's Avatar
Cool PCV and oil consumption
Appreciate the response. I am actually taking it to the dealer. I learned that Audi will cover the Excessive oil consumption issue I have. We're sucking down a quart every 3 to 400 miles under normal driving conditions. I called the dealer and they said I was out of warranty and then called AoA and they confirmed that I am NOT out of warranty even at 79k miles on a 2010 CPO that we got in 2011. If the dealer doesn't address the PCV issue along with the oil issue, I'll replace the PCV myself. Hopefully this process goes quickly because my state inspection is up at the end of the month.
royalcrown
May 19, 2014 12:10 PM
MXZ1983
Jun 16, 2010 09:31 PM
runamukk
Aug 25, 2009 03:23 PM
bbbzerk
Mar 21, 2009 11:31 PM
pimphell
Mar 22, 2008 04:19 AM
