Vehicle light malfunction indicator came on
Old Jul 23, 2020 | 11:46 AM
gpisano01's Avatar
Default Vehicle light malfunction indicator came on
Hello, I have a 2010 Audi A4. The other day the yellow Vehicle light malfunction indicator came on. I noticed my driver side headlight is out. I tested the bulb and switched the bulb from the passenger to the driver side but it still does not illuminate. All the other lights work in the headlight, so Im not sure what the heck is going on. All other lights work on the car as well. Does anyone know what I should check next? There doesn't appear to be any fuses associated with the LFT Headlight also so no luck it being a fuse.
Old Oct 10, 2020 | 05:37 PM
ppgoal's Avatar
I see no answers, so let a rookie attempt to help. I believe there is a ballast involved in the HID headlights, if that is what you have. Google that. The other possibility is a failed ground. After that I am out of ideas and wish you well because electrical gremlins suck. Let us know when you find it.
Old Sep 12, 2021 | 10:02 PM
Dutch29's Avatar
Where might the bad ground be located? I have a similar problem. Thanks
AudiFanatic123
Jul 19, 2011 05:04 PM
tmic0723
Jan 19, 2011 10:56 PM
mdemisem
Feb 11, 2009 08:06 AM
Snowwake8
Jun 10, 2008 01:43 PM
AZAudiA6Q
Dec 28, 2007 09:33 PM
