5000S battery access?
Old Oct 22, 2007 | 09:43 PM
gtroth's Avatar
Default 5000S battery access?
It's not my car (it's my mom's 5000S) - but have to drop by and replace the battery, and I don't have a lot of time to fuss with it when I get there, so any tricks or tools I should bring?
I know battery is under the back seat.
Many thanks.
Old Oct 27, 2007 | 12:43 AM
InExile's Avatar
Default RE: 5000S battery access?
noe no tricks
Old Oct 29, 2007 | 07:22 PM
gtroth's Avatar
Yeah, no problem. Two screws just below front of bench, then lift bench.
Old Oct 30, 2007 | 06:45 PM
Kloudy's Avatar
Why are you taking the battery out. If you want to jump the car then there should be a jump terminal under the hood. If you are just looking to replace the battery the seat should just slide forward then up. Only other thing you might need is a 10mm wrench to disconnect the battery.
Old Oct 30, 2007 | 10:12 PM
gtroth's Avatar
Cars been sitting for a while and I thought I might have a buyer for it. Didn't want to spend time charging - wanted to fire it up and let him drive it.
Coolant reseviour was empty - used to use some coolant when last it ran topped it up. Fired right up but now the oil light won't go out when rev'ing even though oil level is fine. Little puffs of smoke comming from head gasket area. So I'll probably junk this car. Too bad, beautiful interior.
peterbalazs
B8 Models
Mar 30, 2014 07:41 AM
Joe Mazza
Jan 24, 2012 12:31 PM
nw04jen
Audi Q7
Aug 10, 2011 10:30 PM
ToddLower
May 14, 2009 08:44 PM
teabreak
Mar 26, 2006 05:35 PM
