85 UR quattro
Old Aug 10, 2014 | 12:08 PM
  #111
team illuminata's Avatar
I just found this quote from the ad when I bought the car a few years ago:
"The car has a modified head and a modified ECU to allow use of the Euro wastegate spring."
What do you think they did? Maybe I should contact the previous owner.
Old Aug 10, 2014 | 12:45 PM
  #112
Isn't Google amazing? From the previous previous owner's ad:
"Modifications include,,, port matched intake and exhaust, multiangle angle valve grind, chipped ECU with euro wastegate spring"
Doesn't mention anything about the cam but I am intrigued by "chipped ECU" now.
Old Aug 14, 2014 | 12:57 PM
  #113
I disassembled the turbo, manifold, down pipe and waste gate over the weekend. It put up a bit of a fight but nothing a bit of heat and an impact gun couldn't handle.
10565123_4610214029899_5116158346131189916_n by Team Illuminata Motorsport, on Flickr
12499_4610214269905_7151674819689183790_n by Team Illuminata Motorsport, on Flickr
10457859_4610214869920_4568737449148905272_n by Team Illuminata Motorsport, on Flickr
10561801_4610215109926_4604287780690867317_n by Team Illuminata Motorsport, on Flickr
The manifold is cracked. Need to decide whether to repair it or install the later Audi "fix" manifold.
There is a little play in the turbo bearings so I think I should have it rebuilt. Any recommendations for a rebuilder?
Should I rebuild the waste gate too? I've been told they wear over time and bleed off boost.
Old Aug 15, 2014 | 05:39 PM
  #114
Progress is slow. Please stop ordering wheels so I can work on this car more LOL. Oh, I meant "Please order more wheels so I can afford parts for this car".
Today is brought to you by the letter Oil Pump.
10384228_4610215349932_1361418370398512838_n by Team Illuminata Motorsport, on Flickr
10580268_4610215709941_197495448913129139_n by Team Illuminata Motorsport, on Flickr
and Cleaning pistons. I used gasoline and a soft wire brush. A lot of grease from my elbows helped too.
10505297_4610216269955_8716098810117373762_n by Team Illuminata Motorsport, on Flickr
Old Aug 19, 2014 | 02:31 PM
  #115
Old Aug 22, 2014 | 08:00 AM
  #116
So I'm ready to start putting this engine back together but I'm still not 100% convinced my refurbished head is correct for the WX engine. Are the 38mm intake valves and slightly smaller cam lobes stock for the WX?
Of course I will need a head gasket and apparently new head bolts for this job. I assume these should all be OE right? Any suggestions where to buy (USA preferably). I'll obviously need a few other seals and gaskets but I might have them in my parts stash already. If you noticed anything that wasn't pictured above let me know.
Time to turn the corner on this project.
Old Aug 22, 2014 | 10:36 AM
  #117
Oops, sorry. I forgot to post these two pictures. First one shows the oil and coolant passages on both heads, To me they seem identical.
10632582_4650881886570_1801364765633948559_n by Team Illuminata Motorsport, on Flickr
I'm a bit concerned about how some of the oil and coolant passages were seemingly blocked (red) or partially blocked (yellow) by the old head gasket. Is this normal?
10575274_4650904727141_1521189660366053610_o by Team Illuminata Motorsport, on Flickr
Old Aug 23, 2014 | 08:39 AM
  #118
bradtyler02's Avatar
Old Aug 24, 2014 | 10:52 AM
  #119
Originally Posted by bradtyler02
Old Aug 24, 2014 | 10:58 AM
  #120
It looks like my refurbished head has hydraulic valves after all so it was decided to refurbish the head that came off. To that end I ripped into it. Not sure it's going to work out though.
10423694_4662952268322_3665118206738515884_n by Team Illuminata Motorsport, on Flickr
10599410_4662952428326_1516271255718620755_n by Team Illuminata Motorsport, on Flickr
10616674_4662952308323_4959051653940620140_n by Team Illuminata Motorsport, on Flickr
10423694_4662952388325_6340626939614127018_n by Team Illuminata Motorsport, on Flickr
10569053_4662952348324_4904993497782901578_n by Team Illuminata Motorsport, on Flickr
Can it be salvaged?
