door handle swap possibilities
Old Mar 8, 2007 | 04:18 AM
frankinstyn's Avatar
Default door handle swap possibilities
Hello everyone again. So I really don't like the door handle style of these cars. It looks like its the same design used in the early 80's volkswagens.
So is it possible to swap in a different style?
Here is the car in question...
The ones I prefer are these late volkswagen style....
http://cgi.ebay.com/ebaymotors/Golf-...QQcmdZViewItem
If I have to though, is it possible to put these one instead?
http://cgi.ebay.com/ebaymotors/VW-Vo...QQcmdZViewItem
Old Mar 8, 2007 | 02:19 PM
Default RE: door handle swap possibilities
well I've taken off the driver's handle (locking mechanism came unclipped) and found the problem with these handles.
It looks like the problem is with the door latch mechanism. Swapping over the locking part is very easy (just a phillips head screw). I just have to find a way to swap over the other part of this handle.
This is going to take a bit of research
Old Mar 9, 2007 | 05:50 PM
InExile's Avatar
i'm sure you can think something up and if you make it work and look nice than post a DIY here
Old Mar 10, 2007 | 12:53 AM
I think I will do that. I'm going to wait until my check comes in and see what I can do. From the looks of it it should be really quite easy and besides, I need a project. I'll do a DIY on it as I go. Don't know how many people are interested but from what I've heard the stock door handes have a habit of breaking so maybe this can be another option instead of simply replacing them.
Hey, who know? An all chrome handle might look quite nice.
Old Mar 14, 2007 | 01:13 AM
InExile's Avatar
yes the stock handles are a bit ugly and do tend to brake in cold wether if not lubed regularly
Old Mar 14, 2007 | 02:41 AM
URQ's Avatar
URQ
I used the Volkswagen Chinese door handles On my Urq and I like them a lot.
Old Mar 14, 2007 | 02:54 AM
Really? Do you have the central locking system? How did you get it to work properly with that?
Old Mar 14, 2007 | 12:48 PM
URQ's Avatar
URQ
Yes I have the central locking system but I have 1 actuator on my master door for the alarm system. And I just had to modify one of the rods that gos to the lock mechanism because the latch is lower on the door for the 4000 then the VW you might have to do the same. But as far as the central locking system I am sure you can make it work without the actuator just by modifying the rod abit.
Old Mar 14, 2007 | 12:53 PM
URQ's Avatar
URQ
Also the first door handles that you show require you to weld a new plate of metal in the door and then you still have to modify the linkage.I dont think you want to do that?
Old Mar 14, 2007 | 01:03 PM
I would like something like those chrome ones but did suspect that those specific ones would not work. I have used those others ones before on my little rabbit and while I like them, I would prefer chrome. I'll take a walk through a junkyard and see if I can find any Audi handles that might do the trick.
audi guru
Jun 6, 2013 04:39 PM
bauer1185
Apr 30, 2009 03:02 PM
OchoCinco
Aug 14, 2008 08:24 AM
genedaddy
Mar 2, 2008 12:43 PM
Hotazlava32
Jan 30, 2008 11:37 PM
