How bad is the clutch replacement on A90TQ
Old Oct 17, 2007 | 11:50 AM
comrade904's Avatar
Default How bad is the clutch replacement on A90TQ
How bad is a clutch job on an audi 90 turbo quat? I have a porsche 924S with that 944 engine so I know timing belts, and how special toolsare needed. Plus the two are family. Is there a depository of info for A90's or online shop manuals?
Old Oct 17, 2007 | 11:58 AM
techbod's Avatar
Default RE: How bad is the clutch replacement on A90TQ
simplish if you done it before, its an in-line engine and not transverse if its like the UK model and only too you need is a clutch plate line up tool and not expensive
edit: blasted spell checks only TOOL needed
Old Oct 18, 2007 | 05:26 PM
comrade904's Avatar
How bout the Throw out bearing? how long can you drive without it?
Old Oct 19, 2007 | 09:55 AM
NH_USA's Avatar
Forever (or until you run out of gas) as long as you don't have to shift!
If it is making noise it will ultimately fail and there will be nothing to release the pressure plate.
If failure is imminent don't sit at lights or in traffic with the clutch depressed. Put the car in neutral and take your foot off the clutch so it dosen't sit there spinning with a load.
PS always change the T/O bearing when doing the clutch --
erectorset
Aug 11, 2010 07:55 PM
pfrontin
Aug 17, 2008 08:54 PM
mattr7786
Aug 14, 2007 01:25 PM
uptown
Jun 29, 2007 11:22 PM
AdLucem
Mar 8, 2006 07:28 PM
