problems with heater core
Old Feb 15, 2014 | 11:30 AM
radosc39's Avatar
Default problems with heater core
Have a 94 cabriolet with no heat: how do you flush or clean out the heater core? is it hard to get to? freezing in Ky!
Old Feb 16, 2014 | 12:13 PM
hubturn's Avatar
Rado. Reading your other posts, you have two problems. First is to deal with the overheat. Probably a bad thermostat but could be a bad water pump. It matters not that the job was done 20K ago. I had a thermostat crack in less mileage than that. If you do the job, you need knowledge first. Go to 12v.org and read up on the system, then read the How-To for timing belt replacement. You cannot replace the thermostat without doing this whole procedure no matter what some people say. You need the cam holding tool, the crank shaft holding pin, a gear puller and, a torque wrench. You can get all that on Ebay or some autoparts houses rent them. About $100 on ebay. Other Audi sites have some tech articles discussing the procedure.
Old Feb 17, 2014 | 05:34 PM
hubturn's Avatar
almost forgot. Since you changed the coolant, did you use G-11 or G-12? If not, flush the prestone or whatever out of there and redo the job. Also, the system has to be bled of air or you can get a vapor lock and the car will overheat. The hose that connects to the heater core has a knurled plastic nut that you open to vent the air. This can be a repetitive process and is a bit of an annoyance. Do not drop the plastic nut or that will be $35 for a new hose. There is another vent nut on the coolant pipe behind the left head, but forget about getting that opened up. You will strip out the allen head for sure, and it takes a bit of work to get to anyway.
a4quattguy
Jan 1, 2013 01:49 AM
e30bmw318is
Dec 9, 2009 04:00 PM
parox
Jul 16, 2009 10:53 AM
vgo
Jan 21, 2009 06:07 PM
Danbert
Dec 15, 2007 01:39 AM
