Water Temp. Sending Unit - Dead???
Old Jan 24, 2008 | 12:53 PM
typ 44's Avatar
Default Water Temp. Sending Unit - Dead???
5000cs Turbo
Water temperature gauge in the dash is dead no reading.
Can you damage the water temperature sending unit by cleaning it (with a wire rotary brush on a drill), or by mixing up the connecting wires (does it matter what wire connects to what terminal on the sensor, can you short it out?)
Put in a new radiator the other day, took the thermo switch (for the fan) off the old radiator and put it on the new one. But first cleaned it a bit with a wire rotary brush on a drill, noticed that the water temperature sending (looks like a big hex bolt with connection pins for the wires on the under side, on side of the cylinder head) had some scale build up, so cleaned it as well (same wires brush method). Put everything back together no problem, however not sure if I miswired the water temp. sensor. It is the updated one with 3 pin terminals (opposed to the original 4 pin type), it was wired with quick disconnects because the old connector was in bad shape, so it would be easy to mix up the wires if one did not note them (if each wire does a specific pin to connect to, how do I determine this now?). Fired the car up to check out everything and noticed that the Temp. gauge was giving no reading, and it took a really long time for the fan to kick on.
Old Jan 31, 2008 | 06:39 PM
Avant Sport's Avatar
Default RE: Water Temp. Sending Unit - Dead???
Check this page on SJMautotechnik.
http://www.sjmautotechnik.com/troubl...ing.html#gauge
slfalco
Feb 15, 2012 12:47 AM
kiellish
Oct 11, 2009 10:44 PM
A4 Mike
Sep 3, 2009 07:52 PM
A6 Quattro V6 30V
Mar 14, 2007 12:41 PM
slocumnb
Mar 22, 2006 11:45 AM
