Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
100 2.5 TDI engine Change !! Help ..
Old Mar 2, 2006 | 07:00 PM
Mostin's Avatar
Default 100 2.5 TDI engine Change !! Help ..
after some advise , pointers or anything you gents can think of ...
my father bought a 100 2.5 TDI with a blown engine , with it was a "replacement". Set to work changing them over ....
now both have the engine code AAT , virtually identical engine ( believe the repalcement came from a 97 A6)
notice one difference in the fly wheel , so we used the orginal . problem is that we can't get any fuel through the pump , even if the pump is primed , NOTHING !!!
the crank shaft has a sensor which is in a different postions , on the 100 its located in the bell housing but on the A6 it's nearer the sump
anybody have any ideas ??
thanks
Mostin [sm=dontgetit.gif]
Old Mar 2, 2006 | 09:03 PM
kakarot's Avatar
Default RE: 100 2.5 TDI engine Change !! Help ..
hmm, did you check the pump.
check if anything in the pipes, like grease or something. Diesels have tandency to be a little dirty.
The sensor should be identical couse the signals are same.
Old Mar 3, 2006 | 06:48 AM
Mostin's Avatar
hi kakarot
fellow Dragon ball fan ???
thanks for the advice ... i will certainly check ... the pump was a runner until the original engine blew , usual senario in UK next ... guy took it to a local garage who quoted him over £2k to repair !!!
it's a lovely motor so was ashame to let it go to waste , i'll let you know how i get on
cheers
Mostin
Old Mar 6, 2006 | 06:33 AM
Mostin's Avatar
hi
checked pipes etc , there all fine !!
the pump from the 100 & A6 are 99% idenitical but there are some slight differences , we've got a diesel specialist not far away ...
so i think the cars gona be towed down there & see what he can find , if all fails theres a 2.8 Quattro engine my dad has his eye on , that could be going in , be ashame as he wanted the car orginally for the MPG but if all fails , MPH will win !!
cheers
Yuffy
Feb 7, 2015 01:59 PM
whoisthis
Apr 16, 2010 10:52 AM
Tourbo24
Mar 24, 2010 08:44 AM
chebert69
Jan 3, 2007 01:03 AM
Audi4Life
Mar 19, 2005 09:11 AM
