104 octane
Static, just curious. Where would you be getting 104 octane fuel? Is that airplane fuel or something?
My understanding is octane rated fuel is recommended due to compression ratios. Have you done some motor work increasing your C/R?
Just getting ethanol free mid grade gas is a challenge here. Only sold as "marine" fuel at 30-50 cents more a gallon.
Unless you are running a tune for 104 octane fuel you are not going to gain anything from it, in fact if the tune is for pump gas you will most likely see a decrease in power since the timing will not be advanced enough for it.
