Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
2.7T - data log numbers
Old Jun 16, 2011 | 02:09 PM
vtraudt's Avatar
Default 2.7T - data log numbers
I had my 2.7T custom tuned (aggressive tune, 93 oct, stock configuratoin; no data logs) and later removed the pre cat and main cat (same tune). The car felt VERY strong, and logged data confirmed:
Max MAF: 250.5 g/s at 6400 rpm
Max Torque: 458.6 Nm at 3000 rpm
Max HP: 303.9 HP at 6480 rpm
Max Boost: 18.1 psi at 3000 rpm
With the cats removed, we retuned the car yesterday, but did NOT manage to get any improvements:
Max MAF: 256.8 g/s at 5760 rpm
Max Torque: 438.1 Nm at 3200 rpm
Max HP: 296.3 HP at 6920 rpm
Max Boost: 20.2 psi at 3680 rpm
The 'butt meter' confirms. Maybe a little more lively above 4k rpm, but less 'torque hammer' around 3k.
What are the numbers out there for the 2.7T (VAGcom logs)?
Giac, APR, etc for Stage 2 (? gutted pre cat and eliminated main cat, rest stock)?
Why are we not seeing improvements that I expected from the surely reduced backpressure and increased exhaust flow?
What is the next bottleneck that I an tackle without spending much?
Larger turbos have to wait until year end
Old Aug 27, 2011 | 03:53 PM
T67's Avatar
T67
Max MAF: 277.6 g/s at 5603 rpm
Max Torque: 458.3 Nm at 3200 rpm
Max HP: 320.8 HP at 6900 rpm
Max Boost: 18.1 psi at 3100 rpm
Tuned by MTM, pre cat is out, running on 98 oct everythingelse stock.
Old Aug 27, 2011 | 06:07 PM
vtraudt's Avatar
VERY nice! good to see that there is quite a bit of room left on the stock motor.
LOVE your torque number (already like mine a lot).
Old Oct 26, 2011 | 03:09 AM
terryalice's Avatar
coll dude
good to see these..............its......its really cool
Old Sep 2, 2012 | 10:54 AM
ratherb1's Avatar
Necro bumping this thread ....where are you guys getting these numbers from dyno?
Old Sep 2, 2012 | 11:35 AM
vtraudt's Avatar
Data logging:
Vagcom, ECUx, nefmoto logger, etc.
They are all in your ECU.
Great way to check out the effects of those 'feel good mods' (like "really hot air intake", K&N filter, "Darin Intake mod".
But also a must for fine tuning custom tunes (your tuner will tell you what and how to log).
Old Sep 3, 2012 | 09:26 AM
ratherb1's Avatar
Yeah I just logged my car for the first time a couple days ago.... Results where not so good
Old Sep 3, 2012 | 09:44 AM
vtraudt's Avatar
Post results!
the more logs we have the better.
Particularly MAF, IAT, (Torque if you have).
Old Sep 4, 2012 | 08:56 AM
ratherb1's Avatar
Where should I post them in the main forum or right here?
bmoore98A4
Aug 3, 2011 01:49 AM
vtraudt
Dec 21, 2010 11:37 AM
danceingbuck
Oct 6, 2007 09:06 PM
AudiTurbo
Sep 17, 2006 04:54 PM
