Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Cheap power, Diode, MBC, and Boost gauge install
Old Dec 31, 2007 | 01:32 PM
  #101
cincyTT's Avatar
I'm make believe
Default RE: Cheap power, Diode, MBC, and Boost gauge install
Already answered the first question. No, your not damaging the engine, the engine is stout and can hold way more than what a ko3 can throw at it.
Old Dec 31, 2007 | 03:37 PM
  #102
Audi_Skydiver's Avatar
ORIGINAL: B5 owns
Thanks alot for the help man, I got two more questions though.
1. You are pumping more air into the engine with this mod, but since its not a chip, you dont add any fuel, so does the computer compensate for that or do you just run a higher air ratio over the fuel ratio? Yes, the computer compensates for the extra air. If you read the posts that has been said about 500 times now.
2. With more air pumped in and increase in pressure in the cylinders, wouldnt that be harsher on the engine? (part of my reliability question) In a way yes but the engines are designed well and it won't cause any problems. Just look at some of the other guys who are running BT setups with over 100K miles and they don't have any problems and they are pushing A LOT more air in than this would ever do.
Josh
Old Dec 31, 2007 | 03:38 PM
  #103
Beat me to it. LOL
Josh
EDIT: 3000th POST!!!!
Old Dec 31, 2007 | 04:23 PM
  #104
texasboy21's Avatar
Hey cincy my boost gague and MBC are in the mail so expect some pms about tuning after new years.
barrett
Old Dec 31, 2007 | 04:37 PM
  #105
B5 owns's Avatar
Your right, sorry for asking the same question, just didnt think it through. Thanks alot for your help and the nice way to answer my questions.
Old Jan 1, 2008 | 04:59 PM
  #106
B5 owns's Avatar
If i want to run a MBC with this, is this a good one? Also, what type of MBC is this? is this a bleed/ ball&spring?
Old Jan 1, 2008 | 05:01 PM
  #107
NO!!! Stay away from that one!!! I have had nothing but problems when I had it on mine. I eventually just took it off. There have been others who also have had problems as well.
Josh
Old Jan 1, 2008 | 06:08 PM
  #108
B5 owns's Avatar
What about either this turbonetics or the NXS:
Old Jan 1, 2008 | 06:20 PM
  #109
cincyTT's Avatar
I'm make believe
The turbonetics is a bleed and is fine, the cheap bottom one is a ball and spring is not a good choice.
Old Jan 2, 2008 | 02:36 AM
  #110
B5 owns's Avatar
Is the turbonetics MBC better than these two?
Hallman:
Or:
Also, would this be a good guage? http://cgi.ebay.com/ebaymotors/2-52m...ayphotohosting
Where can I find this diode?
