Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
In dash display problems?
Old Jan 22, 2008 | 08:14 PM
BryanB's Avatar
Default In dash display problems?
So after reading the owners manual, I discovered the volcano in the dash meant I was low on washer fluid. I filled it up but the warning indicator failed to go off. I also just spent about an hour in the frigid cold checking my brake light bulbs because I also have that warning flashing at me when I drive. Nothing wrong with the bulbs. Other warnings I am experienceing are defective bulb (none found) and brake pads (possible).
Do I have to somehow manually reset the warning indicators in the dash? I read through the manual and didn't find anything.
thanks for the help...and be gentle on the noob, please.
Old Jan 23, 2008 | 07:56 PM
BryanB's Avatar
Default RE: In dash display problems?
anyone?
Old Jan 28, 2008 | 12:16 AM
pimphell's Avatar
maybe your dash is bad?? I dont know if all of them go off
Old Jan 30, 2008 | 04:03 PM
audiS4jls's Avatar
how cold is it where you are? it could be possible that the fluids aren't getting to certain places because it's so cold... try warming the car up and see if it doesn't go away.
you could also hit the button that does a check on the washer fluid, oil, battery, etc. and seeif it'll magically reset itself.
Old Jan 30, 2008 | 04:08 PM
audiS4jls's Avatar
How cold is it where you are?I guess it could be possible that some parts of the car are frozen and the fluids aren't getting there. Try warming up your car to see if it goes away.
You could also try clicking the button on your dash that checks your oil, washer fluid level, battery, etc. and see if it magically fixes itself.
Old Mar 2, 2008 | 11:26 AM
rego222's Avatar
When the Pixels in Message Center is working wrong, This is a major problem in the TT's, If I have this problem should I fix it right away or leave it like that and the car will not give me far more electrical problems. Did any body knows how much or how to fix this problem? Thanks
bdesp66
Jul 20, 2014 12:43 PM
Bass402
Nov 29, 2006 12:27 PM
noid73
Nov 14, 2006 12:20 PM
LuckyCharmsUXZ
Jun 1, 2006 06:08 PM
FootIntheGrille
May 20, 2005 11:03 PM
