Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
obd 'link error"
Old Sep 17, 2008 | 08:47 PM
millenia's Avatar
Default obd 'link error"
check fuses and wires still wont connect to OBD, man this is pissing me off, where is obd computer
Old Sep 19, 2008 | 03:00 AM
Prizmatik's Avatar
Make sure the key is in the ignition and turned on to where the lights on the dash and guages are lit. Sometimes on these cars, you have to rerun the linking process with the OBD tool. If it doesnt work the first time, rescan without changing anything (dont turn the key off and on again, leave it on!), if that doesnt work, try again. Good Luck!
Old Sep 19, 2008 | 10:40 PM
millenia's Avatar
well tried that couple times still nothing, any other suggestions???
Old Sep 21, 2008 | 06:48 PM
Prizmatik's Avatar
You can also try to leave the OBD tool plugged in and still on after a link error, turn the ignition off for a few seconds then turn it back on, and run the linking process again, you may need to try this a few times also.
I have had vehicles give me trouble like this but eventually link with the car with enough experimenting. Good luck, keep us posted.
You may also want to try with the engine running. Dont plug/unplug the scan tool while the key is on or engine running.
auditurbo381
Aug 7, 2015 02:27 AM
idfnl
Oct 11, 2010 11:47 PM
AUDIFIELD
Mar 13, 2010 10:11 PM
