B6 2002 RIGHT HEADLIGHT DOESN'T WORK & a "DIPPED" DASH ERROR. WANT TO GET HIDS!
Old Nov 6, 2009 | 11:09 PM
domenicostorino's Avatar
Question B6 2002 RIGHT HEADLIGHT DOESN'T WORK & a "DIPPED" DASH ERROR. WANT TO GET HIDS!
Hello!
just got my 2002 A4 3.0 Quattro 6 speed manual. The car doesnt have HIDs. The right headlight low beam bulb doesnt work. I get a "righ dipped headlight" error in the dash.
I was thinking on getting a replacement H7 bulb (correct me if that is not the right one) but instead I want to get HID s! I can see millions of kits on ebay for about $60, I have gotten several of those in the past to install in hondas/toyotas... pretty straight forward installation.
Is the installation the same on a B6? when I went to check the back of the headlight for a quick view, I had no easy access to the bulb, pretty different than other ones I've seen.
Is it true that if I install HID lights I would get an error message (another one...) in the dash?
Old Nov 8, 2009 | 03:25 AM
Dan1969's Avatar
Don't buy the ones from E-bay. Check out DDM for some HID stock look, I like the way they look on our cars. I got the stock ones that came with my car. I believe our number is D1S or something like that, I might be wrong.
Old Nov 8, 2009 | 04:13 AM
so is there anyone who can guide me on the bulb installation process and also on how to get rid of the dipped headlight error? thanks!
Old Nov 8, 2009 | 07:17 PM
pa4ul's Avatar
the right dipped error is becuase the bulb dosent work. As dan said check ddm for the hid kits. Its vitrually plug and play to stock. U just need to find a spot to mount the ballast for the hids. Most people like to mount it underneath the housing as their is a spot for it. U will also need to drill a hole in the rear cover for the main bulb for the wires to go through. IT seems hard but in all seriousness should only take about 20 minutes tops. If u need any more input lemme know.
Old Nov 8, 2009 | 09:38 PM
thanks for your help, today I removed the headlight to change the h7 bulb and saw for myself how everything is back there, so I got the idea and now I know how to install them. I don't have the dash error anymore!
I replaced the license plates with some whiter ones (NO leds, just a blue coated reg bulb) and now they don't turn on. Switched those with the factory ones and they don't work either... does anybody know what happened??
Old Nov 9, 2009 | 12:42 PM
pa4ul's Avatar
like stated on the other thread check those tabs to make sure the are making proper connection. MIght want to scrape the connections to ensure u get a good flow of current. IF u do go the led route get autolumination bulbs no flickering or codes.
Old Jan 31, 2013 | 05:29 PM
Slowride's Avatar
Headlight & parking light don't work
Old Mar 6, 2013 | 08:35 PM
Marine702's Avatar
HID Kit, HID Conversion Kit, HID Headlight Kit for Cars & Trucks at HIDNation.com
If you have auto on lights you need the relays, plus you need the CANBUS cancellers.
Theyre really affordable too
ChrisSparky
Nov 25, 2017 01:06 AM
ebag99
Mar 8, 2012 10:11 AM
mbono8
Jan 31, 2012 03:04 PM
mrfredo82
Jan 3, 2011 09:02 PM
05a632
Nov 16, 2009 03:34 PM
