petrol gage not working??
hi iv got a audi a4 3.0 l .....the car was driveing all ok then it just cut out and would not start
..the petrol gage said it was half full .. so we throught it was the alam. once we worked out it was not the alam. we had a look at the in tank pump. and once removed you could see in to the tank and there was not a drip of petrol in there....so we put it back together and put some petrol in and it started
happy boy. BUT now the petrol gage shows empty all the time and the computer says 0miles in the tank even when the tanks so full you can not get any more in it
. is there a way of reseting it or might it be the sender on the pump
please help as it driveing me nuts
thanks for any help and info jamie
Defective Dash Voltage regulator (Voltage limiter) or gauge
Lost of a ground at the sending unit
Break in the wire going to the dash
On some Chryslers, the Bulkhead connector on the firewall or connector behind kick panel.
this are few common problems.
(rude comment deleted by Devil)
Remove the sending unit from the tank, clean the resistor element with electrical contact cleaner, and re-solder the wire that is very likely broken on the sender (that's the problem 99% of the time). Reinstall and you're good to go.
hi tryed that. and once the pump was out the wire looked to be ok but the float had come away and was in the bottom of the tank. once i got that out i give it a clean and put back together but still nothing ??? wot might you try next mate. thanks jamie
AndY_C
Jun 14, 2010 02:17 PM
larrye2001
Nov 26, 2005 08:05 PM
