Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
petrol gage not working??
Old Sep 23, 2011 | 07:18 PM
jamie1210's Avatar
Default petrol gage not working??
hi iv got a audi a4 3.0 l .....the car was driveing all ok then it just cut out and would not start..the petrol gage said it was half full .. so we throught it was the alam. once we worked out it was not the alam. we had a look at the in tank pump. and once removed you could see in to the tank and there was not a drip of petrol in there....so we put it back together and put some petrol in and it startedhappy boy. BUT now the petrol gage shows empty all the time and the computer says 0miles in the tank even when the tanks so full you can not get any more in it. is there a way of reseting it or might it be the sender on the pump please help as it driveing me nuts thanks for any help and info jamie
Old Oct 22, 2011 | 03:35 AM
Gerrell20's Avatar
Defective Dash Voltage regulator (Voltage limiter) or gauge
Lost of a ground at the sending unit
Break in the wire going to the dash
On some Chryslers, the Bulkhead connector on the firewall or connector behind kick panel.
this are few common problems.
(rude comment deleted by Devil)
Old Nov 7, 2011 | 09:41 AM
ImTheDevil's Avatar
Remove the sending unit from the tank, clean the resistor element with electrical contact cleaner, and re-solder the wire that is very likely broken on the sender (that's the problem 99% of the time). Reinstall and you're good to go.
Old Feb 19, 2012 | 11:22 AM
jamie1210's Avatar
hi tryed that. and once the pump was out the wire looked to be ok but the float had come away and was in the bottom of the tank. once i got that out i give it a clean and put back together but still nothing ??? wot might you try next mate. thanks jamie
jamie1210
Aug 7, 2011 07:32 PM
toboater
Oct 26, 2010 12:15 PM
mfcineurope
Jun 26, 2007 04:57 PM
larrye2001
Nov 26, 2005 08:05 PM
