Oxidation? What should I do next?
Old May 25, 2007 | 04:03 PM
nabujam's Avatar
Default Oxidation? What should I do next?
Hello,
After a while of not being sure of why my hood was getting more milky (and a few more waxes), I decided to get smart and look to audi forums. Figured out it is some type of oxidation and waxing would not help my problem. I used a clay bar which didn't do anything for the oxidation, but the hoodbecame smooth. I used Mothers pre-wax cleaner, which cleaned a lot of the problem, but it is not 100%. Can someone give me suggestions as to what to buy, what to do, and any other info.
I still don't exactly know why it was happening.
Here are a couple of pics.
Thanks,
NB
[IMG]local://upfiles/9627/E03D5535846D4137B8F083B7338A1B38.jpg[/IMG]
[IMG]local://upfiles/9627/DF1F1EA2865B4E0ABB0AB4AD7528AED3.jpg[/IMG]
[IMG]local://upfiles/9627/E07684AFF847450289339CB3BB0E706B.jpg[/IMG]
Old May 25, 2007 | 04:14 PM
techbod's Avatar
Old May 25, 2007 | 07:12 PM
nabujam's Avatar
Default RE: Oxidation? What should I do next?
Dave,
Do you know what product I should use specifically?
Thanks,
NB
Old May 26, 2007 | 05:11 AM
TOGWT's Avatar
For highly oxidized paint try the following;[/i][/b]
Wash the paint surface and dry thoroughly
Clean the paint with chemical paint cleaner (Klasse All-In-One) using an orange foam pad at speed #4, this may take 2-3 applications
Once the oxidation has been removed use a decontamination system (Auto International A B C System (http://www.autoint.com)
Apply an oil rich product to stabilize the paints binder system (3M Imperial Hand Glaze) apply a thick coat and allow to dwell for 12-24 hours before buffing, repeat as necessary until surface has an ‘oily’ sheen.
Remove residue and apply a Carnauba wax (Zymol Concourse)
Try to keep vehicle paint surface away from UV heat radiation
Keep paint surface waxed on a regular basis.
Unfortunately if the clear coat is failing a repaint is the only permenant fix.
[ul][/ul]
Old May 26, 2007 | 12:43 PM
nabujam's Avatar
Thanks for the thorough response. I'll buy the stuff and try it out in the next week. I'll reply to tell you how it went.
audi704
Oct 1, 2014 01:32 AM
gigglebeans
Oct 12, 2012 02:52 AM
Audi-above60
Nov 1, 2011 02:54 AM
gottwinns
May 5, 2008 04:49 PM
