oxidation removal???
Old Apr 25, 2008 | 08:22 AM
gottwinns's Avatar
Default oxidation removal???
anyone know how to remove oxidation that appears on the lenses of the headights with out doing damage to the lens itself?
Old Apr 25, 2008 | 11:47 AM
Coors's Avatar
Default RE: oxidation removal???
Get a 3M clay bar, not the liquid clay bar product. This will not only remove oxidation it will remove any and all clear coat contaminants. Just use caution when using! Make sure the surface is wet and you will be fine. If the surface is dryyou will rub through the clear, which is obiviously a bad thing. You can use it onall metal painted surfaces, glass (winshield), plastic, and whatever else you can think of.
It's a detailer's secret weapon!
http://www.3mestore.com/60980034767.html?WT.mc_id=3M-com-AtoZ-clay-car-cleaner
Good Luck!
Old Apr 25, 2008 | 12:07 PM
gottwinns's Avatar
thanks for the help, but do you know where i can buy it?
Old Apr 25, 2008 | 12:13 PM
Coors's Avatar
Try the link I gave above
Old Apr 28, 2008 | 01:45 PM
Joeski's Avatar
If the oxidation is severe, a clay bar will clear it up but not completely. The end result will be wet sanding and polishing with Meguires PlastX.
OOOO
Old Apr 28, 2008 | 09:11 PM
gottwinns's Avatar
i ended up just wet sanding it with 1200 grit and then i put a clear coat on the headlights so it wouldnt happen again
Old Apr 30, 2008 | 12:42 PM
Joeski's Avatar
ORIGINAL: gottwinns
You will find that you will have to polish your headlights regularly. I use PlastX on my headlights everytime I wax my car. I wax my car 4 times a year. It really helps keep the lens clear, clean and removes oxidation, bugs, etc.....
OOOO
Old May 3, 2008 | 12:03 AM
audia6s's Avatar
wondering if too much waxing is bad for your car or no? Like once every 2 months.
Old May 3, 2008 | 09:34 PM
ericgl's Avatar
Washing is likely to do more damage.
Old May 5, 2008 | 04:49 PM
quattrofreak's Avatar
ORIGINAL: gottwinns
None of thepolishing techniques last it will come back unless you keep up with it like joeski says. The best way is to sand plastic prep and clear them unfortunatley the only way to get a quality job is to pull the light out and do them. Then you can tint them a little too.
[IMG]local://upfiles/51957/C49B3C74A4C6476FB19ACB2AA86D54C2.jpg[/IMG]
audi704
Oct 1, 2014 01:32 AM
gigglebeans
Oct 12, 2012 02:52 AM
Audi-above60
Nov 1, 2011 02:54 AM
99a4wagon
Dec 10, 2010 07:03 PM
nabujam
May 26, 2007 12:43 PM
