DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
B5 5 spd tranny fluid change by Sandman
Old Oct 26, 2005 | 09:04 AM
Jestnomen's Avatar
6th Gear
Default B5 5 spd tranny fluid change by Sandman
This was done on a 98.5 30v 5 spd audi a4
it wasnt hard if you can change oil you can do this
you will need a special bit because the drain plug is tamper proof, i got mine at www.germanautoparts.com
it was a bit expensive ($25) but it is needed and it will work on both the drain plug and the filler plug.
first off drive your car around untill the fluid has heated up, this will allow the fluid to drain easier.
jack your car up
here is the special bit, along side the drain plug and fill plug.
un screw the drain plug and wait till all the old fluid has trickled out
heres where the drain plug is, its right on the bottom of the tranny, you cant miss it
replace the drain plug and remove the fill plug
the fill plug is the large bolt in the middle, it is on the drivers side of the gear box near the axel
i used mobil 1 75w90, fully synthetic, this is what the manufactuer reccomends and it took about 3 quarts
you will need some sort of way to get the fluid up in to the filler whole, u used this pump type of thingie, you
can get it at any auto parts store.
pump it full.
the tranny will take more than 3 quarts but this is only because the car is jacked up and at an uneven slant, again only add 3 quarts
as you can see i needed this
and now my shifts are smoother than ever
torque listings
fill plug=18 ft/lbs
drain plug=26 ft/lbs
Butternuts
Apr 5, 2008 07:13 PM
JaceTun
Mar 15, 2008 12:01 PM
DENIS415
Aug 14, 2006 07:46 PM
dougdanger
Dec 31, 2005 06:58 AM
