DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
DIY - Clean/Change Throttle Body (1.8t AEB)
Old Jul 1, 2010 | 04:22 PM
chocalotstarfish's Avatar
Super Moderator
Default DIY - Clean/Change Throttle Body (1.8t AEB)
It's pretty basic but I couldn't find a write up for the basic mechanics!
Need:
Throttle Body gaskets $1.49 (Advanced Auto)
Phillip Screw Driver
5mm Allen Wrench
Vice grips
Throttle body cleaner aka carb cleaner $2.25 (Advanced Auto)
Shop towls
q-tips
1st this is what your throttle body looks like right in the middle.
Start by disconnecting your battery (important in the end)! then remove the hose from the body (phillips screw driver) Unplug the clip at the top
Now there are 4 bolts holding the body to the manifold (5mm Allen) Mine were pretty tight and as leverage to get off I used vice grips.
Once all off you should now be able to undo the throttle cable and the body is all free!
You will notice black/brown junk is the throttle body that is BAD there might even be some just inside the manifold.
Spray it with the cleaner and used shop towels to wipe out, in those hard to reach ares use q-tips!
Q-tips work great on the ends of the butterfly!
Once all done should be clean and shiny I even took the time to clean the outside since mine was pretty nasty! see 1st and last pics!
Put every thing back in reverse order not forgetting the new gasket!
Now reconnect your battery. Put your key in the ignition and turn forward but DO NOT start the car, go listen to the throttle body it should be making a high pitch kind of noise, that is good! once the noise stops you can start her up! Hope this helps anyone that might need it!
Old Jul 1, 2010 | 04:39 PM
ImTheDevil's Avatar
Nice writeup - I vote a move by Admin to the DIY section.
Old Jul 1, 2010 | 04:46 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Seconded.
I'll be cleaning mine fully and maybe polishing it before I install my polished intake manifold.
Old Jul 1, 2010 | 05:40 PM
Baby Kito's Avatar
Third.
Nice write up!
Old Apr 14, 2012 | 07:33 PM
SassPB's Avatar
Thanks a lot! Been looking all over for this information!
Old Apr 14, 2012 | 10:24 PM
crazyquik22023's Avatar
Nice DIY..
Old Apr 14, 2012 | 11:35 PM
ImTheDevil's Avatar
I'll move it now to DIY.
scMaverick
Jan 24, 2014 12:43 AM
xaudia4x
Apr 5, 2010 03:28 AM
munichman
Jul 25, 2008 04:38 PM
wurdup
Oct 20, 2006 01:44 PM
sandnsnow24
Aug 17, 2005 04:52 AM
